GotHeliRC
http://gothelirc.com
Hey all,
135usd
http://www.gothelirc.com/shopexd.asp?id=2717
We just got the Tarot ZYX-M flight controller in stock.
The revolutionary flight controller
With multiple new technologies, Tarot ZYX-M simplifies all complicated operation and brings you easy and natural flight experiences.
To upgrade the flight features, ZYX-M is equipped with smart computing and navigation control systems. Pilots can adjust tilt, roll, and pan axis through setup software according to different preferences.
Furthermore, it supports fail safe and voice alarm, including range setting and no-fly zone alarm. ZYX-M keeps the multi-copter under control during flights.
Main controller:
135usd
Main controller:
- 32 bit processor
- Built-in anti-vibration sensor
- Full metal case
- Supports dual S-BUS receiver
- Supports dual DSM satellite receiver
- Specific Interface for TAROT gimbal control
- GPS module:
- Highly efficient GPS receiver
- High gain antenna
- Fast and accurate locating
- PMU module:
- Dual power output
- Supports power output to flight controller, gimbal, and video TX in the same time
- Integrated voltage test
- Low voltage alarm
- LED indicator:
- Indicates the multi-copter status in real-time
- Standard accessory: USB module
- Download:
http://www.tarotrc.com/Download/Detail.aspx?Lang=zh-cn&Id=15b775d6-e7f9-4ed2-8ccd-80cbe9840ac6
Features:
Support 9 kinds of multi-copter. With 3 servo ports for higher compatibility
- Accurate speed control under GPS mode:
Under GPS flight mode, the flight speed is proportionally equal to joystick movement, and the level speed is proportionally equal to throttle stick movement.
Failsafe, one key go-home, IOC(Intelligent Orientation Control), POI(Point of Interest):
If the multi-copter lost the signal, it can return to launch and land. When the signal works normally, pilot can pull and switch and activate one key go-home.
Smart retractable landing gear:
Once activate the feature, the landing gear will automatically extend in emergency case (ex: auto-landing). Pilot can control the landing gear through radio transmitter after flight height exceeds 5 meters.
Flight range programmable and no-fly zone protect:
Under GPS flight mode, the multi-copter will fly inside the setting range only. Under other flight mode, once the multi-copter fly outside the setting range, the auto return-to-launch will be activated. In places near airport and no-fly zone, the flying height and range are restricted.
Prop failsafe (Hex-copter or above)
For Hex or above copters, when one of the motor or prop doesn�t work, the multi-copter will fly normally.
