Taranis Throttle Position Timer
Algae2
Good evening all!
First off, I'm greener than green.
I'm trying to get acquainted with the Taranis. With that being said, I need help in setting up a timer for throttle position percentage. In other words, I would like the timer to start once the throttle stick position goes past 15% for example. I think I know how to set up the reset switch (page 11) which at the moment I'm considering is to use "SH".
Thanks in advance,
Alex
IIRC, you need to make the timer have the trigger of TH%. That way one of the timers will only be counting when the throttle goes above a certain % of the stick throw.
I sont not have the model in front of me, but I'm pretty sure that should work. I'll take a closer look at my Tx when I can.
There is also a Taranis Owners Thread in the main section of the forum. Some decent info there and some knowledgable people to help out.
