Overview
There are a wide variety of Apple and Android devices available. It's important to make sure you're using a device that is powerful enough in order to prevent the DJI GO app from lagging, freezing, and/or crashing during use. The following list includes devices recommended by Phantom Help (►), devices recommended by DJI (►), and other devices that are most often recommended by Phantom pilots.
Apple Devices
►►iPhone 5s--(4 inches ― A7 chip)
►►iPhone 6--(4.7 inches ― A8 chip)
►►iPhone 6 Plus--(5.5 inches ― A8 chip)
►► iPhone 6s--(4.7 inches ― A9 chip)
►► iPhone 6s Plus--(5.5 inches ― A9 chip)
►► iPhone SE--(4 inches ― A9 chip)
►►iPad Air--(9.7 inches ― A7 chip)
►►iPad Air 2--(10 inches ― A8X chip)
►►iPad Mini 2--(7.9 inches ― A7 chip)
►►iPad Mini 3--(7.9 inches ― A7 chip)
►► iPad Mini 4--(7.9 inches ― A8 chip)
►► iPad Pro--(9.7 inches ― A9X chip)
► iPad Pro--(12.9 inches ― A9X chip)
Note: Both Wi-Fi only and cellular iPad Air/Mini/Pro models are compatible. Only cellular models have GPS. You do not have to enable the cell service in order to use the GPS. The DJI GO app currently only requires GPS on an Apple device when using the Follow Me feature or to reset the home point to your current location if you've moved elsewhere after taking off.
Note: Tablets wider than 6.75 inches (including the case) will require an extender to be installed on the remote controller mount. The iPad Air will fit without case. This extender is designed well and will securely hold a tablet that's up to 8.25 inches wide.
Note: Your Apple device will work better out of the box if you follow these tips.
Android Devices
►►Acer Iconia Tab--(8 inches ― 1.33 GHz ― 2 GB RAM)
►► Acer Iconia Tab--(10.1 inches ― 1.3 GHz ― 1 GB RAM)
►►Google Nexus 5--(5 inches ― 2.3 GHz ― 2 GB RAM)
►►Google Nexus 7 [2013]--(7 inches ― 1.5 GHz ― 2 GB RAM)
►►Google Nexus 9--(8.9 inches ― 2.3 GHz ― 2 GB RAM)
►►HTC One--(4.7 inches ― 1.7 GHz ― 2 GB RAM)
►►Huawei Ascend Mate 7--(6.8 inches ― 1.3 GHz ― 2 GB RAM)
►►Huawei P8 Max--(6.8 inches ― 2.2 GHz ― 3 GB RAM)
►►Lenovo A3500--(7 inches ― 1.3 GHz ― 1 GB RAM)
►► Lenovo Tab S8-50--(8 inches ― 1.86 GHz ― 2 GB RAM)
►►Nubia Z7 Mini--(5 inches ― 2.0 GHz ― 2 GB RAM)
►►Nvidia Shield K1--(8 inches ― 2.2 GHz ― 2 GB RAM)
►► RCA Voyager II--(7.1 inches ― 1.4 GHz ― 1 GB RAM)
►►Samsung Galaxy Note 3--(5.7 inches ― 2.3 GHz ― 3 GB RAM)
►►Samsung Galaxy Note 4--(5.7 inches ― 2.7 GHz ― 3 GB RAM)
►► Samsung Galaxy Note 5--(5.7 inches ― 2.1 GHz ― 4 GB RAM)
►►Samsung Galaxy S4--(5 inches ― 1.9 GHz ― 2 GB RAM)
►►Samsung Galaxy S5--(5.1 inches ― 2.5 GHz ― 2 GB RAM)
►►Samsung Galaxy S6--(5.1 inches ― 2.1 GHz ― 3 GB RAM)
►►Samsung Galaxy S6 Edge--(5.1 inches ― 2.1 GHz ― 3 GB RAM)
►► Samsung Galaxy Tab 2--(7 inches ― 1.0 GHz ― 1 GB RAM)
►► Samsung Galaxy Tab 2--(10.1 inches ― 1.0 GHz ― 1 GB RAM)
►►Samsung Galaxy Tab 3 Lite--(7 inches ― 1.2 GHz ― 1 GB RAM)
►►Samsung Galaxy Tab 4--(7 inches ― 1.2 GHz ― 1.5 GB RAM)
►► Samsung Galaxy Tab 705c--(8.4 inches ― 1.9 GHz ― 3 GB RAM)
►► Samsung Galaxy Tab A--(8 inches ― 1.2 GHz ― 1.5 GB RAM)
►► Samsung Galaxy Tab A--(9.7 inches ― 1.2 GHz ― 1.5 GB RAM)
►► Samsung Galaxy Tab E--(9.6 inches ― 1.3 GHz ― 1.5 GB RAM)
►►Samsung Galaxy Tab Pro--(8.4 inches ― 2.3 GHz ― 2 GB RAM)
►► Samsung Galaxy Tab Pro--(10.1 inches ― 1.9 GHz ― 2 GB RAM)
►► Samsung Galaxy Tab Pro--(12.2 inches ― 1.9 GHz ― 3 GB RAM)
►► Samsung Galaxy Tab S2--(8 inches ― 1.3 GHz ― 3 GB RAM)
►► Smartisan T1--(4.95 inches ― 2.5 GHz ― 2 GB RAM)
►► Sony Xperia Z2--(5.2 inches ― 2.3 GHz ― 3 GB RAM)
►►Sony Xperia Z3--(5.2 inches ― 2.5 GHz ― 3 GB RAM)
►► Xiaomi Mi 3--(5 inches ― 2.3 GHz ― 2 GB RAM)
►► Xiaomi Mi Pad--(7.9 inches ― 2.2 GHz ― 2 GB RAM)
Note: Tablets wider than 6.75 inches (including the case) will require an extender to be installed on the remote controller mount. This extender is designed well and will securely hold a tablet that's up to 8.25 inches wide.
Note: The DJI GO app currently only requires GPS on an Android device when using the Follow Me feature or to reset the home point to your current location if you've moved elsewhere after taking off.
Note: Your Android device will work better out of the box if you follow these tips.
Note: If you're not able to install DJI GO from the Google Play store, you'll need to sideload the DJI GO APK.
Apple Devices
Android Devices
