oschefer
I've been following the forum for a while now and have been flying a DJI 550 for a bit over a year. I bought a T960 about the same time and built it slowly over the last year as I didn't think it was a good idea to go straight to a 960 size. I have flown RC planes for many years so I am not totally new to the hobby but have only been into multi rotors for a bit over a year now. I finally got the 960 together and am having a terrible time getting it stable. The 550 was a very simple build, but the 960 so far .... not so easy. I have a large gimbal ready to go but have not put it on yet (good thing as I doubt it would have survived) I have been very impressed with the strength of the T960 frame, unfortunately, I am testing it a little too often right now. I am hoping someone out there might be able to point me in the right direction.
Basic specs:
Tarot T960
Motors - TMotor 4014 330kv
Props - 17x5.8 Carbon Fiber TMotor
ESC - ZTW spider 40A with Simon K
Battery 6S
Flight Control - DJI Naza V2
Landing Gear - retracts from foxtech the pilot V2 I think they were called
Weight with battery 10.5 lbs (4.7kg) (no camera rig)
Once I add the gimbal with the camera second radio, battery, etc it adds 5 lbs (2.2kg)
unfortunately I have not installed the IOSD Mark 2 yet so do not have logs.
First several attempts to fly, it would tip over on take off. I realized I had not calibrated the ESC so I did that and tried again. Not sure if the lift off issue was the ESC or just trying to go up too slowly but it gets off the ground now...
1st liftoff - tried flying with no gimbal to just get it flying knowing re-tuning would be needed. Then Naza gains were up in the 175 range if I remember. The battery was mounted on top so I think it was top heavy
video is here :
I moved the battery under it and tried again. It was much better but still not stable. I had the gains tied to some dials on the remote to try tuning but it didn't help much.
Second successful flight (kinda) I upgraded the NAZA firmware and also found in the newer DJI manual sample gains for an S900. The S900 is a similar sized frame and in their sample used similar kv motors and similar props. The gains were way down near 100 so I started there. I also added a 5 pound dumbbell to simulate the camera and gimbal. It was much better but still wobbled after making an input. Total weight 15.5lbs (7kg)
video is here -
I did some more reading and watching of videos from others. Found a video online where a guy had changed his ESC then started to have what looked and sounded like a similar wobble/drift. This got me thinking about the ESCs. In the instructions it mentions some low kv motor may need to have the motor timing set vs using the auto mode. I set them all to 2 degrees and tried again. This time I used 2 batteries vs the dumbbell so it was 13 lbs. (5.9kg) This left the power distribution accessible if I was going to make more changes. The results were not good see video
video is here -
Any ideas? Has anyone used these ESC with the TMotors? I am leaning to replacing all the ESC with another brand.
Basic specs:
Tarot T960
Battery 6S
video is here :
video is here -
video is here -
