MombasaFlash
Heli's & Tele's bloke
There must be a whole load of bog standard S800/WKM/Z15 setups out there and I suspect that very few folks use the default gain values as they all seem a bit high and possibly too reactive for AP. How about those with this standard setup posting their gain settings so that we can get an idea of the mean values? Naturally there will be a few differences according to LiPo size and weight, plus any other mods, but a ballpark average guide for this particular platform should become apparent after a while.
Below are my 'Auto-Pilot' settings:
210 : Pitch
210 : Roll
120 : Yaw
195 : Vertical
130 : Attitude Pitch
130 : Attitude Roll
Another thing. Atti mode will make all the calculations it requires to hover with the Tx stick at (or around) 50%. Manual mode requires around 70% Tx throttle - with my current settings. This means either a drop, when switching from Atti to Manual, or an increase in altitude when switching from Manual to Atti.
The manual states that the 'Vertical' parameter has no effect upon the Manual mode so the question is, is it possible to configure WKM so that the two modes have a similar hover throttle stick setting and thus reduce this differential?
Third item. I went back to FW5.16 from 5.18 when the latter made no difference to the altitude loss issue that is a current hot topic and which also affects FW5.16. The problem really only appears with a bit of wind. Is this altitude loss thing resolved or improved in FW5.20? Or is it still a haphazard condition that does not affect everyone?
This is partly why I have started this Gain Settings thread, to try and isolate conditions under which altitude loss could happen.
210 : Pitch
210 : Roll
120 : Yaw
195 : Vertical
130 : Attitude Roll
