GotHeliRC
http://gothelirc.com
Robo-Q 740-820mm heavy lift Quadro/X8 with retracts
Hey all,
Let see what you guys think of this 740mm folding frame that can be set up as Quadro or X8 with retracts. I have been flying this more than a month and it's smooth and stable. I personally like how easy you can fold the arm and not having to detach the prop or required folding prop. Any one interested or suggestions?
Here's some specs.
* Load 1.2KG
* Dimension: 740mm
* Height: 350mm
* Center plates thickness:2.0mm
* Distance between center plates: 40mm
* Diameter of booms, landing gear:22mm
* Gimbal rail tubes: 12mm
* Distance between gimbal rails (center to center): 112mm
* Frame weight: 1.3KG (with retractable landing gear)
* No-load weight: 3.95kg (contain a 10,000mah 6s battery)
Hey all,
Here's some specs.
* Load 1.2KG
* Dimension: 740mm
* Height: 350mm
