RC Multistar High Capacity 4S 16000mAh Multi-Rotor Lipo Pack NEW
gene smith
Want to dramatically increase your multi-rotor flight times without the penalty of added weight? We have just the solution! The all new Multistar high capacity batteries are the result of extensive testing and development with one goal in mind...increasing flight times for your multi-rotor aircraft without the penalty of added weight. We have achieved our goal by drastically increasing the battery capacity (mAh) while lowering the discharge rate. This results in a battery which is still capable of providing sufficient current (Amps) while offering much higher capacity when compared to a standard 20C+ LiPoly battery of the same weight. What this all means is that Multistar batteries are able to provide flight times much longer than standard LiPoly battery packs without adding any weight to your multi-rotor model, making them absolutely ideal for use with aerial video and FPV multi-rotor aircraft. We have a full range of Multistar High Capacity Multi-Rotor battery packs in the works and will be adding new sizes/configurations as they become available. Be sure to checkout the product video for more in-depth info about these all new high capacity multi-rotor battery packs. Features: • Ultra high capacity LiPoly batteries designed specifically for multi-rotor use • Similar size/weight as batteries of much lower capacity, making these a direct drop-in upgrade for most multi-rotor aircraft • Provides increased flight times of up to 20% or more when compared to standard LiPoly batteries of the same weight • Ideal for use with aerial video and FPV multi-rotor aircract Specs: Minimum Capacity: 16000mAh Configuration: 4S2P / 14.8V / 4Cell Constant Discharge: 10C Peak Discharge (10sec): 20C Pack Weight: 1290g Pack Size: 173 x 74 x 45mm Charge Plug: JST-XH Discharge Plug: XT90 $69 US BUYER PAY SHIPPING AND HALDING
