Jareth_Atian
I am considering purchasing a HoverflyPro and HoverflyGPS for my next hex. I will admit, however, that I am a bit confused by the flight-modes and controls as described in the manual(s). I don't suppose that I could get some feedback and see if I'm on the right track? I definitely have questions...
From what I understand, controlling the flight-modes of a HoverflyPro w. GPS requires three switches: Two two-position switches and one three-position switch.
The first switch turns Auto-Leveling on and off.
The second switch turns Altitude Hold on and off.
The third switch (The three position switch) controls GPS functions: Off, Position Hold and Return To Home.
Note: This represents 12 combinations.
In addition to these flight modes, there is also 'carefree' mode which (from what I understand) must be enabled in software rather than by a switch. This doubles the number of possible flight-mode setting-combinations to 24.
From what I understand, DJI's 'Attitude' mode is the equivalent of Hoverfly's Auto-Leveling + Altitude Hold.
DJI's GPS Attitude mode is the equivalent to Hoverfly's Altitude Hold + Position Hold
Carefree mode is the equivalent of DJI's Intelligent Orientation Control in Course Lock mode, but apparently only works when Auto Leveling is turned on.
The manual mentions that the Hoverfly can't be armed while Altitude Hold is enabled. Can it be armed while Position Hold is enabled? Can Altitude Hold be turned on after the Hoverfly is armed but before it has launched?
It seems to me that Position Hold has the side-effect of keeping the craft level over a fixed point; how do the flight characteristics change if Auto-Leveling is enabled as well? If Auto-Leveling changes the flight characteristics of Position Hold flight, does it also change the flight characteristics of Return To Home? How so?
Will carefree mode work when the GPS switch is turned to the 'off' position?
