Prop type
phillip1993
Could changing my props from carbon to abs cause problems as I've changed them and loter is now a bit unstable and is there an easy way to fix this thanks
Sent from my LAUDE S500 using Tapatalk
HexaTiger
Did you change prop length as well? I know different size batteries (3S/4S) perform better with different prop lengths.
Also, did you balance your new props?
phillip1993
No same size and pitch and same 3s battery and it only seems to be when its a little windey
HexaTiger
The only other thing I can think of the is the inherent difference in the material properties of ABS verses Carbon Fiber.
