OK I am at a complete loss here.
Everything is set up as should be, Wookong settings all working as should be.
Was just going to calibrate the ESCs throttle.
This is the problem, I cant even get it to work, cant even get into the programming part.
My ESCs were pre-programmed before I got them, so disconnected the Lipo turned transmitter on and put throttle up full, and plugged Lipos in.
Get the normal 1,2,3 then 4 secs later 1 more beep.
Nothing is reversed.
Disconnected all the motors, took 1 ESC and plugged it into the RX channel 3, my end points are all set to 100%, plugged lipo in and get a constant fast beep, that tells me that the throttle position is high.
I cant even get into program mode, and it wont calibrate, I have tried setting throttle end points lower and still the same thing.
I am using Hobby Wing Flyfun Opto ESCs, with Futaba 14SG and R70008SB rx through S-Bus on a Hexacopter-V
http://www.hobbyhot.com/hobbywing/hobbywing_manuals/HW-01-V4.pdf
Everything works as it should, all sticks/motors etc, it just wont let me into calibration/programming mode.
Anyone any ideas what I may be doing wrong?
