Hello guys, I am new to this forum so was not sure where to post it hopefully no problem here.
I NEED SOME SERIOUS HELP !!!
Here is my story:
Bought the flypro x600 fpv rtf waited for about 40 days to get it. For some reason when I built it I could not arm the motors but I figured out the problem was I had to bring out the drone to the nature to get proper gps signal for first calibration in the naza lite software. But I just followed all the steps what the assemling video provided by hobbyking and I havent checked touched any setting in the naza software. So I was so thrilled to arm the engine but didnt mean to fly with it at all. When I turned on it was flipping over like hell, only 4 props were working and I ended up breaking 2 props. Eventually the idle speed was setted for 50% and the orientation was quadrocopter instead of hexa V... but hell I didnt mean to fly with it, I just wanted to know if this drone works at all.
Ordered new props, took me 10 days to get them, Ordered 6 fortunately because they are not the same as the stock, so of course I changed them all to make sure it wont drift.
First test flight: I still cannot take off because it want to flip over. Yes I was reading many article and youtube you should get at least 50% power so that way it will take off properly and the gps will do the rest. Still no success, feels like one engine is working the opposite direction, but before I built it apart and rewiring the cables(as I can see you have to cut the cables, not plug from A to B the wires) I wanted to check some setting in the devo 7 Controller since I have not touched it only calibrated. But at the same time my 8 batteries what I just bought at the beginning died... and I was flying 0 minutes lol... I had to get rechargable batteries and charge them, but had to wait a day for that. SO Everything charged and I was setting the devo, and I noticed the type was at aero instead of heli. Not sure which one is better for a hexacopter. Anyone could explain me? I did some reset in the settings and everything got screwed. When I turn on the tx and plug th MC and power it, I cant calibrate and set anything in the NAZA Software, CFG ERR NAZA... also that could cause an update because I installed an older version as well, but I ended up deleting the software but same issue. After a day of switching modes somehow I got it back working in the naza software, everything was set to be able to calibrate. Calibrated even outside, but when I try to arm the engines yellow led flashing rapidly... so after half days of trying no success but I figured out that means no gps signal so my transmitter has to be recalibrated because I noticed it was in FAIL SAFE in every switch.
So in the naza I could calibrate everything but when I switched from manual/gps/atti, always was in safe mode, anything I tried didnt work.
After all I figured out I had to do a FIX ID or whats that called in my transmitter and I setted up a new mode and resetted everything else, that solved the problem and now I have atti in the naza software BUT I CANT CALIBRATE WTF......... so its the opposite, I have gps and nothing works inside and CFG ERROR again...... tried to reinstall the software didnt work out... I cant even go to the step to take off the props and check if they work as it should be because I cant arm the motors. I am 100% sure its because of the transmitter, but not sure what to do, how to factory reset the entire settings, or how to set up a completely new mode... I was checking youtube videos, and setted up as a dji f 550 should have but still same config error and now red flashing rapidly... I know that means I have to recalibrate the devo 7 but I did it 5 times and still same problem
I have no idea what to do and all help would be much appreciated, anyone out had the same problem?
PLease help me out
Its been more then 50 days and 0 minutes of flight time
Adrian
Here is my story:
PLease help me out
Adrian
