PowerDrone-serie Airframes from the netherlands
RC Helipower drone specialist is about to launch the new PowerDrone-serie Airframes . The principle of those frames is "more for less" .The structure of the centerpiece is, that it is bolt less (only the arms are secured by plastic bolts )The Powerdrone is Super light, half the weight of all frames now in the Market ( like Droidworkx, Cinestar, Flexacopter etc. )The PowerDrone will be highly rigid because of the 31mm build-up laminate.( laminate is composed of 8 different materials like; aramide / honeycomb carbon etc.) It has a great design, will be very stong and payable for everyone ! It can be upgraded with a lot of things for example, with our Carbon Fiber Wire Damper System, that is adjustable for the weight of your camera, gimbal and lipo combination.
Measurements of the booms will be;
Powerdrone 4 16x14x300 mm
Powerdrone 6 16x13x420 mm
Powerdrone 8 16x13x450 mm
Option
for these three systems, Anti Vibration Wire system will be available soon
More pictures will be available soon !
yeehaanow
Seems like a good idea.
Interested to see the final product.
If you made center frames with 25mm boom holes then any person with a cinestar could use their booms. :)
