Power distribution board or harness?
Is there any drawings or how to about making a wiring harness? or should I order a Power distribution board?I would really like to make my own wiring harness though.also what is the plug the fits on the control board pins called and where can I get those?
RTRyder
Merlin of Multirotors
Either way works but I've found the distribution board method weighs a lot less than the wire, solder, and shrink wrap necessary to make a harness. Once you bolt the board down you can run the wires from battery and ESCs and eliminate any bullet connections or large amounts of solder needed to connect wires in a straight wire harness, IMO makes for a cleaner installation with less potential trouble spots.
