Need Help! Please Help - can't get BetaFPV and TinyHawk2 working
scotiwis
Hi, hopefully someone can help as I am losing hair rapidly.
I purchased locally here in New Zealand:
BetaFPV LiteRadio 2 FrSky
TinyHawk 2 BNF
I am totally new to drones/quads so I read first that I need to bind them by changing the radio to D8, which I did, and then hit Bind on the radio and the TH.
They definitely appear to be communicating as after I bound them the lights on the TH change when I power the radio on and off, also when I flick the SC switch to the upper position all the lights on the TH come on and it beeps continuously.
Moving the throttle up on the radio has no effect on the TH though.
So I next read that I need to assign one of the switches on the radio to ARM - is that correct?
To do that I installed BetaFlight Configurator on my pc (Windows 10) and installed the STM USB and CP210x drivers (installed both coz no clue which I need).
I then powered on the radio and attached it to my pc via USB.
In Device Manager the radio showed as "BETTER_USB_HS" under libsub-win32 devices
Betaflight couldn't detect it (just shows COM1 and can't connect) so I followed instructions for Zadig and ImpulseRC Driver Fixer
In Zadig I chose "BetaFPV Taranis Joystick" and changed the driver from libusb to WinUSB (v6.1.7600.16385).
This resulted in Device Manager showing "BetaFPV Taranis Joystick" under USB Devices
Still no change in BetaFlight (choices are COM1 or Manual but both say 'no configuration received' when I hit Connect)
I then tried ImpulseRC Driver Fixer but it just sits at "searching for flight controller" forever
I also tried installing the demo of FPVFreeRider but it couldn't detect the radio either
I attempted all of the above on a different pc and a laptop, exact same results.
I also tried multiple USB cables, even bought a new one that specifically states data transfer + charge, but same results.
So I have no clue where to go from here.
I'm assuming I'm correct in thinking that I need to set a switch on the radio to 'arm' to make the throttle work?
And that I specifically need Betaflight to do this?
Any advice greatly welcomed!
den5000
TinyHawk 2 BNF
Low quality and terrible customer service don't buy it..
I sincerely regret that I bought this from them. First of all I bought drone and two batteries for it. One battery arrived dead. Drone stopped working during first attempt to fly it. But when I contact them to change it (I understand that it complicated electronics and things happened). They propose me to fix it by myself even if it under 30 days warranty. Do not buy from them. There is plenty other drone makers around.
https://i.imgur.com/I6ayDNGl.jpg
