JoshMaxAmps
I am building an 250 size quad and have run into an issue I thought you guys might be able to help with. I programmed using Cleanflight software. I also have a Futaba 10J Tx.When plugged into the software and on the receiver tab I see the inputs I do on the transmitter on the screen but unfortunately the yaw or turn feature is not moving at all. I checked the Tx and it is in multirotor mode and that movement should be tied to the rudder so it is correct. I also confirmed by moving the stick and the tx recognizing its movement. Looking at the Naze 32 board the solder job is solid and it looks clean. The wire from Naze to the receiver looks good as well.
Is there something I am missing? Any troubleshooting tips? Thanks!
