So I had this together first go around and she flipped cause I had a prop on wrong, then I fixed the prop and it still wanted to flip over so I took it all apart and am trying again but I am having the same wonder I had the first two go's at this and that is when I plug the battery in my ESCS (hobbyking 40a) only give a solid beep vs the naza start up song my phantom makes. any ideas?
I found out after making this video.... Manufact. site says
But where in my naza jingle!?! Doesn't its absence indicate somethign wrong? (Using a Naza V2 with X8r rx). I calibrated each arm individually.
【Normal Start-up Process】
Turn on the transmitter and move the throttle stick to the bottom position.
The motor will emit a long “beep----“1 second after the system is connected to the battery indicating the ESC is armed and the multi-rotor is ready to go.
