Night Flying - LED Orientation and Setup
I was wondering the best setup for night time flying? I mostly fly after 7pm and i have managed to loose track of the single LED on the VRU/NAZA not fun.
Tonight after a fair amount of planning I mounted a few strips of Turnigy LED's to my DJI Flamewheel 450. The results were an obvious improvement and I was quite impressed with everything.
Since this was the first night of flying I have many questions and as always look to improve my night time experience.
http://www.youtube.com/watch?v=xRs7npy90aQ
1. In any way will it effect the life of the battery or the onboard voltage monitor of the DJI NAZA if I utilize the Conditioning cable for the LED's power?
2. To control lighting i purchased a Multi-Remote Receiver operated on/off Switch. It a great device that has 7 ports , I am using 3 does a way exist to disable them so I can go 123 off, 321 off?
3. My front legs are white with white led's and the rear are red/red led's. For orientation I formed a pointer to the nose of the flamewheel. Any better setup for the Green LED?
4. Removing the Gel from the LED to expose the solder joint. How the hell do i clean it easily? I used needle nose to cut & snip it away followed with a q-tip and rubbing alcohol to expose the pad. Any easier way?
Thanks for your input.
JK
Jake Bullit
Fly,crash,glue,repeat!
I have leds permantly on my Y6 with negligible battery drain.
I use red on port,green on starboard and white on the tail.
If I see red/green left/right its pointing away from me.
green/red left right its facing toward me.
Red/white sideways pointing to my left
Green/white sideways pointing to my right.
