1001 Copters
Hi there
A new reference rize for the FPv lovers
after the diversity, we have now the quadriversity !
This item will allow you to use four antenna to have a very large cover of the sky while flying.
For example if you use 4 Helix 3.5 turns, you can cover up to 240° of the sky !
You can use this item with 4 different transmiter to have 4 video flux or you can use it as a quadriversity to have the best transmission switched to the antenna that have the better signal.
Frequencies used:
CH1: CH2 5705Mhz: 5685Mhz CH3: CH4 5665Mhz: 5645Mhz
CH5: CH6 5885Mhz: 5905Mhz CH7: CH8 5925Mhz: 5945Mhz
Best regards,
Cédric
Frequencies used:
Best regards,
Cédric
