NEW...
OUR NEW PRODUCT, PAN X 360 HAS PLUG&PLAY MECHANIC WITH REAL CONSTRUCTION.HOWEVER,GIMBAL HOUSING SUITABLE FOR ALL TYPES OF ADAPTERS.EASY INSTALLATION AND PROFESSIONAL SHOOTING.
PAN X 360
roperties of A class ; Ready to using-plug and play two way-compatibility of gimbal and multicopter’s frame-Precise cornering ability-High Tork
FLASH,FLASH,FLASH
You will be able to turn your camera gimbal with 2.axis that you have to 3.axis with PAN X.This product return easily your heavy multicopter.Two-way system:A)product allow to wiring on the model’s gyro.B)product allow to wiring on the gimbal’s gyro.
TECHNICAL SPECIFICATIONS:
*Weight: Only 300gr.
*Chassis:7075 aluminum anodized.Internal mechanical 6061-T6 aluminum.Double bearing 12mm Hollow shaft.
*Servos:Hitec HS422 Deluxe.360 degree continuous rotation(modified)
*Reduction:7.1 reduction.With HS 422 servos include : 4.8volt 22kg,6volt 28kg tork =
4.8 volt 7 kg - 6 volt 9 kg HEAVY LİFT
PAN X 360
FLASH,FLASH,FLASH
