New CHARGER#X7 PLUS DUAL POWER 80W 3
dexport
Never used. Euro 40.00
SPECIFICATIONS
Input voltage: 11-18 V or 100-240 V; Charging current: 0,1-6,0 A; Discharge current: 0,1-2,0 A; Power charge: 80W; Power discharge: 10 W; Weight: 560 g; Dimensions: 146 x 135 x34 mm; Cell types: NiCd / NiMH: 1-15 cells | LiPo / LiFe / Li-Ion: 1-6 cells | Pb: 1-10 cells
DESCRIPTION
The X-Treme Charger X7 Plus is a compact computer battery charger, which is able to charge and discharge all types of batteries in a most professional way. The X7 Plus features special charging programs for NiCd, NiMH, LiPo, LiFe, LiIon and Pb batteries. As a special feature, the X7 Plus is equipped with a balancer function for lithium batteries. Thus it is guaranteed that all cells in the lithium pack accurately obtain the same charging level. Furthermore the X7 Plus charger has the option to connect a temperature sensor. The charge current can be adjusted between 0,1-6,0 A. The discharge current can be selected between 0,1-2,0 A. There are five memory spaces available, where different profiles for batteries can be stored. So you do not have to enter the same configuration again and again. Battery packs can be maintained and created by special cycle charge programs. The X7 Plus is designed for dual input power and can be operated with 230V~ or 12V= as well.
