James Goodwin
Hi,
New to the forum and to Quads, but not to the Rc World.
I am hoping there is someone out there that can give me a little advice. I have built my new ZMR250 following Bruce's instructions over at RCmodel reviews. The build has gone well but I am stumped with the following.
I am using a Turnigy/FLysky i6 with ia6 RX. I have connected the RX to the Naze with all wires using the breakout cable and I have checked and double checked the connections. Power and ground to pins 1 and 2 naze and signal wires only progressively through to channel 5. I have also confirmed that Cleanflight is configured to use PWM. RX bound and Airplane /glider type selected.
The prob I have in clean flight is that, on the reciver tab the channels are showing, Yaw and throttle are working as they should but Roll and pitch seem to be locked together and only work in one direction. If I push the rh stick up, nothing happens and if I push it left, nothing happens. I do get movement in other directions but bot the roll and pitch moved at the same time. It is almost like there is some kind of mixing going on... but there isnt.
Here is what I have done thus far.
I have uploaded a video for anyone that fancies giving me a guiding hand. Sorry about the quality of the I6 screen and video but hopefully you can get the idea.
Thank you all in advance
- Setup midpoints
- Setup Endpoints
- Wiped the TX to factory, cleared all models
- Double checked that no mixes are on
- Flashed the Naze twice
- Tried cleanflight and baseflight
- Tried a different TX/RX combo ( Ruling out the turnigy i6??)
- Tried various different MAPS in the CLI
- Banged my head against the wall!!!
