NAZA non linear Throttle response
Stratrascal
I hava a NAZA with gps. I had it working pretty good and just needed to program my radio and the assistant software a little better. Now after I arm the motors and increase the throttle the motors stay at the same speed (slightly faster than idle) until I get the throttle to about 70%. I do not have a throttle curve programmed into my radio (JR 9303). I cant figure out what is going on.
Tahoe Ed
If you are taking off in ATTI or ATTI/GPS the Naza sets the hover point at 50% so you will need more than that to take off. If you want to see where your actual throttle position is in take off switch to Manual mode. Most people have to adjust their throttle curve in Manual so there is no rise or fall when switching between modes.
