navigation lights
How are your navigation lights configured?
  • RED-left / GREEN-right / WHITE-tail
    Votes: 4 66.7%
    Votes: 0 0.0%
  • RED-nose / GREEN-tail
    Votes: 1 16.7%
  • RED-nose / BLUE-tail
    Votes: 0 0.0%
  • RED-nose / WHITE tail
    Votes: 0 0.0%
  • Other
    Votes: 1 16.7%
  • No lights
    Votes: 0 0.0%
  • Total voters
    6
Just curious because I see a lot of lighting inconsistencies with different builds - I use Red-left / green-right to be similar to full-size aircraft standards - but I see a lot of red lights out front? I know what's most important is what works for you as a pilot, but shouldn't the multi rotor community be striving for certain standards? Does the FAA have specific nav light requirements for multi's yet?
RCJardin
Not so new and improving
I use Braincube led lighting. It has solved my orientation insecurities. Red-left Green -right Rear - White strobe
Front bright white continuous. Can see in bright sunlight.
AustinFPV
FPV Recon
I did the same but with DeLights from Dimension Engineering. 2 per side (8 total) and programmed to strobe alternately such that the load is constant.
RobertoMFS
Red on left, green on right
I'm think that late or early must be required because it's an standard in the air and in the water.
