XAircraft MY XA quad is spinning/rotating but level on takeoff
noid1037
If this has been addressed I do apologize... My quad 550 is spinning on takeoff but level, not flipping over. All the trims are zero and the quad has been calibrated. The spinning is quick fast.. I wish I could take a video but dont have a third hand to record the video.... is there a solution that I am missing? Im using KDE ESC's.... This is the first time I have seen this erratic behavior. Thanks to the group for the past help!
X650Mouse
Take no prisoners
If you can supply your black box log it will help us to diagnose what is happening.
Initially ensure you have completed the calibration of the SuperX and Radio as per the manual, also if taking off in GPS hold mode you have sufficient satellites showing
X
Photo Elevate
Gravity always wins!!!
Did your Quad previously have a different FC on it before you fitted the Super X
I had this same issue when I swapped out my Hoverfly board for the Super X.
I realised that the CW and CCW prop rotation order is opposite to my previous board.
Swapped them round and problem solved.
Hope this helps.
traxx2003
Noid1037, did you ever figure out what was causing the un-commanded rotation on your aircraft? Having same problem.
