My quad its crazy
Jose luis anez
I have done everything and dont find how to fix it.
I have a naza m lite and phantom tx
Both sticks on my phantom tx are in center position and when i start the motors the quad thinks that im pushing the throthel and its get crazy , its not suppose to understand that center position its his start position and from that point start elevating?
I have done all the configurations but still dont get to fix it
Old Man
Your configs are still not right. The FC is seeing a high value for the ESC's at center stick. Typical mS count for an ESC has 1000 as the low point and 2000 as the high point. If you have the value at mid stick set near 1500 the FC would think half throttle. Use bottom throttle stick position when you arm. If your transmitter has the throttle stick spring loaded for centering, get rid of that spring. As an alternate you could calibrate the throttle channel to be 1000mS at mid stick position, but I don't know what would happen with the stick at less than the center position.
