Hi All,
After seeing some of the pretty spectacular things these machines can do, and having a penchant for anything electronic, I've decided to bite the bullet and put in an order for my first quadcopter. I've put a fair amount research into what I'm getting, but not having done this before, I'd really appreciate some advice! The main thing I want to achieve with this build is decent flight times, good stability and the ability to fly with a gopro/similar, with the option of expanding and possibly adding fpv in the future.
Here is my parts list:
Frame
Hobbyking X650F Glass Fiber Quadcopter Frame 550mm
Props
10x4.5 SF Props 2pc Standard Rotation/2 pc RH Rotation (also got the same kit in Red)
Motor
D2830-11 1000kv Brushless Motor (x4)
Battery
ZIPPY Flightmax 4500mAh 3S1P 30C (with Low Battery Alarm)
ESC
TURNIGY Plush 25amp Speed Controller
Flight Control
ArduFlyer
TX/RX
Turnigy 9XR / OrangeRX
Charger
Turnigy 2S 3S Balance Charger. Direct 110/240v Input
Accessories
Gold Connectors for ESCs
Battery Straps
Power Distribution Board
Turnigy BESC Programming Card
10CM Male to Male Servo Leads
Total cost: $416.76 (which is really at the upper limit of where I want to be, obvious cut would be FC)
eCalc Link - Not too sure if I've got this 100% right!
eCalc
Main questions I have are: In general, will this work? Is the charger appropriate? Is there anything I'm missing, bearing in mind currently I have nothing
Frame
Props
Motor
Battery
ESC
Flight Control
ArduFlyer
TX/RX
Charger
Accessories
Battery Straps
eCalc
