Hi all, posted in the beginners section as well but I'd like to keep the build thread in the correct section, so starting again here.
I've been pondering for a while over whether to buy a rtf quadcopter, or build my own. I quite like knowing how things work though, so decided I'd rather build my own (even if this could potentially cost more/ be a steep learning curve etc...), I want it to be a reasonably cheap build as if I crash it then it's not 1)too expensive to repair, or 2)I won't feel massively attached to it.
So I decided on the HK X550 frame, which I've now received and got built up. I'm still undecided on the electrics, but from watching some videos and reading other threads i'm thinking of copying another I saw (or doing it very similar):
Rx/Tx, battery and charger:
1x Turnigy 9X 9Ch Transmitter w/ Module & 8ch Receiver (Mode 2) (v2 Firmware)
1x ZIPPY Flightmax 2650mAh Transmitter Pack (Futaba/JR)
4x Turnigy AE-25A Brushless ESC
Others:
1x TURNIGY 3~8S Voltage Detector
1x Nylon XT60 Connectors Male/Female (5 pairs) GENUINE
2x PolyMax 3.5mm Gold Connectors 10 PAIRS (20PC)
3x Turnigy 4mm Heat Shrink Tube - RED (1mtr)
3x Turnigy 4mm Heat Shrink Tube - BLACK (1mtr)
1x Battery Strap (5pcs/bag)
3x 10CM Male to Male Servo Lead (JR) 26AWG (10pcs/set)
Motors, propellers, ESC and battery
3x ZIPPY Flightmax 2200mAh 3S1P 45C
4x http://www.hobbyking.co.uk/hobbykin..._Brushless_Outrunner_Motor_UK_Warehouse_.html
1x http://www.hobbyking.co.uk/hobbykin..._UK_Warehouse_.html?strSearch=turnigy accucel
Things i'm still unsure on and need advice on please:
Others:
- Propellers
- Flight Controllers
