I wouldn't start by choosing the frame size.
Have you used eCalc? Not always that accurate but it's a good place to start getting an idea on the size of props, motors and power system you'll need to lift a given payload.
You need to determine the right motor and prop combination that can lift your target weight at 40-50% throttle. Too much less the the drone can become unstable and too much more is inefficient.
For an AUW of about 9Kg I'd start looking at 6S, 435KV motors, and 15" props. Lower 38oKv motors with 18" props would provide more lift and be more efficient but it depends on how heavy your frame and payload is.
Of coarse it's not only about the AUW. The mount of efficiency and weight you can lift is directly proportional to the size of your wallet...
