Low Price Heavy Lift Octocopter for DSLR Suggestion
AM7000000
Hi Guys, I'm new to configure Multirotors, please guid me to complete this system. I need this system for aerial mapping/filming with Nikon D7100/Canon 5D MKIII. Budged is about $3500, most important thing is smooth flying for about 10 min.
I researched a lot but I'm not sure about Motors, ESCs, Propllers, Batteries and I don't know what other things i need.
Thanks a lot.
Frame Parts:
1x Quadframe Foldable Octo Pro frame 1090mm with 495mm arms $320-1400g
1x 310mm clearance landing legs $135-500g
1x DJI and similar controllers support plate $11-20g
1x Protective cage for sixcopter frames $20-40g
1x 175mm clear dome $10-5g
1x Top LiPo battery TRAY $20-20g
Gimbal Parts:
1x XM41170b Brushless Two Axis Carbon Camera Gimbal Kit $160-1000g
1x 2xBM5208-75T Brushless gimbal motor 5D2/5D3D800A900 etc $140-380g
1x EvvGC 3-axis MOS Brushless Gimbal Controller $30-30g
Engine Parts:
8x T-motor MT2826 KV380 30A 75g $720-1500g
8x 13x5.5 DYS Carbon propellers $65-40g
8x Hobbywing FlyFun-40A-OPTO ESC $240-280g
1x 200A Super Hungry Board Multi-Copter Power Distribution $15-130g
Pilot System Parts:
1x HKPilot32 Autonomous 32Bit Control Set w/Power Module $130-155g
1x Ublox Neo-7M GPS with Compass and Pedestal Mount $35-45g
1x Minim OSD v1.1 $20-20g
Communication & FPV Parts:
1x HKPilot Transceiver Telemetry Radio Set V2 (915 MHz) $40-130g
2x Boscam Thunderbolt 2000mW 5.8GHz FPV Transmitter $180-340g
2x SkyZone RC32S 32 Channel 5.8Ghz Auto Scanning Video Receiver $70
1x Mobius ActionCam 1080p HD Camera Set With Live Video Out $70-90g
1x Bar Mount For The Mobius ActionCam $7-60g-10g
1x Fieldview 777RX LCD FPV 800 x 480 with Built-in 5.8 GHz Rx $100
1x Hobbyking 3-Channel FPV Video Switcher $5-50g
Camera Control:
1x Infrared Remote Shutter Controller for Nikon Cameras $10-10g
1X1x Infrared Remote Shutter Controller for Canon Cameras $10-10g
Power Source:
2x Turnigy nano-tech 5000mah 4S 35~70C Lipo Pack $110-1060g
1x Turnigy Nano-tech 2200mah 3S 45~90C Lipo Pack $20-200g
2x Turnigy 9X 9Ch Transmitter w/ Module & 8ch Receiver (Mode 2) (v2 Firmware) $60
Other Parts:
2x Universal Carbon FPV Monitor To Transmitter Mount System $20
2x FPV Monitor Mounting Bracket/Silver-Universal $30
1x Hobbyking™ T682 AC 6s 10A 90W Charger/Discharger $50
1x Hobbyking 2-8S Cell Checker with Low Voltage Alarm $5-25g
1x HobbyKing™ Cellmeter-7 Universal Digital Battery Checker/Balancer $10
1x 6v BEC for camera mount supply $7-25g
Kit Price about $3300 and about 7700g
R_Lefebvre
Arducopter Developer
So you're going to use HobbyKing made flight controller? You might be saving yourself a lot of trouble getting 3DR stuff for only $200 more. Not the least benefit is being able to actually pick up the phone and talk to somebody if you have a problem.
And 2000mW VTx is WAY overkill, and may even give you trouble. I'd suggest sticking to 200mW, and use better antennas. 200mW is plenty out to at least 300m, up to 500m, using CP omni antennas. Use a directional patch on the ground and it'll go much further.
The problem is that much transmit power on the aircraft can cause problems, such as clobbering the GPS.
I'd suggesting using Turnigy 20C standard batteries, no need for the non-tech, and the 20C's might be more reliable.
Is your camera weight included in that 7700g?
