Welcome To DroneVibes
LiDAR vs RADAR Remote Sensing
Discussion in 'Drone Electronics' started by sophia lee, Jan 9, 2018.
  1. sophia lee
    sophia lee Member
    58
    0
    1
    Nov 22, 2017
    china
    Posted by sophia lee, Jan 9, 2018 #1
    LiDAR and RADAR remote sensing are some of the most common remote sensing techniques in use today. LiDAR uses light rays or lasers to send and receive signals while RADAR uses radio signals to send and receive signals to and from an object. But what are the differences between these two remote sensing techniques?
    [​IMG]
    LiDAR Remote Sensing:
    1. Uses laser beams:
    LiDAR technology uses light pulses or laser beams to determine the distance between the sensor and the object. The laser travels to the object and is reflected back to the source and the time taken for the laser to be reflected back is then used to calculate the distance.
    2. Measures precise distance measurements:
    Because of the nature of the laser pulses, LiDAR is mostly used to measure the exact distances of an object. The laser pulses travel at the speed of light which increases the accuracy of the measurements.
    3. Measures atmospheric densities and atmospheric currents:
    LiDAR technology can be used to measure atmospheric densities of various components such as aerosols and other atmospheric gases. This is because the pulses are more accurate and have a shorter wavelength that can be used to acquire accurate data.
    4. Used in obtaining 3D images with high resolution:
    LiDAR technology is capable of creating high resolution images of an object at any surface and this is why it is popularly used in mapping and other topographical uses. Based on the speed of the laser pulses from LiDAR sensors, the data is returned fast and with accurate results.
    5. It is adversely affected by smoke, rain and fog:
    Unlike RADAR technology, LiDAR pulses are adversely affected by atmospheric weather conditions such as dense fogs, smoke and even rain. The light pulses will be distorted during flight and this will affect the accuracy of the data collected.
    [​IMG]
    6. It has a higher measurement accuracy:
    Unlike RADAR, LiDAR data has a higher accuracy of measurement because of its speed and short wavelength. Also, LiDAR targets specific objects which contribute to the accuracy of the data relayed.
    7. LiDAR is cheaper when used in different applications:
    LiDAR technology is cheaper when used in large scale applications. This is because it is fast and saves a lot of time and it is also not very labor-intensive unlike other methods of data collection.
    8. Data can be collected quickly:
    Because of its speed and accuracy of the laser pulses from LiDAR sensors, the data can be collected fast and with utmost accuracy. This is why LiDAR sensors are used in high capacity and data intensive applications.
    9. It does not have geometric distortions:
    LiDAR sensors are highly accurate and are therefore not affected by geometric distortions. The data collected will be precise and accurate and will map the exact location of the object in the image.
    10. It can be integrated with other data sources:
    LiDAR data can easily be integrated with other data sources such as GPS and used in mapping and calculation of distances. This can also be applied in forest mapping and other remote sensing technologies.
    11. It allows for data collection at night and during the day:
    LiDAR technology, unlike other remote sensing technologies, allows for data collection both during the day and during the night. This is because the laser pulses are not affected by light rays.
    12. LiDAR can collect accurate elevation data in dense forests:
    Unlike RADAR, LiDAR sensors are capable of obtaining accurate elevation data from dense forests with distorted canopies because of their high penetration abilities.
    [​IMG]
    13. It allows for detection of small objects due to the shorter wavelength:
    LiDAR sensors can detect even the smallest of objects from the surfaces because of the short wavelength. The data returned will be independent of each object on the surface.
    14. LiDAR can build an exact replica of 3D image of the object:
    LiDAR technology is used to recreate an exact replica of the object being detected and measured in 3D images. This is because of their high accuracy.
    15. It has an operating altitude of between 500m – 2000m
    Lidar has an operating altitude of about 500m-2000m because of its short wavelength. This means it will not be effective beyond these altitudes.
    16. Determines distance to objects:
    LiDAR technology is mostly used to determine the distance to the objects only and no other geometrical characteristics of the object.
    17. It can cover large areas quickly:
    Laser pulses are fast and accurate and can return data within a very short time. For this reason, they are capable of covering large areas within the shortest time.
    18. LiDAR gives very large datasets:
    LiDAR sensors are capable of giving very large datasets because of their ability to cover large areas within a short period of time.
    19. Not guided by any international protocols:
    There are no international protocols that govern the use and operation of LiDAR sensors and data and how to manipulate that data.
    20. Applications:
    LiDAR has a variety of applications including transport, forestry, agriculture, military, and security but its most common applications can be found in agriculture and transport.
    RADAR Remote Sensing:
    1. Uses Electromagnetic waves:
    RADAR technology uses electromagnetic waves or radio signals to determine the distance and angle of inclination of objects on the surface.
    2. It can operate in cloudy weather conditions and during the night:
    Unlike LiDAR, RADAR technology is not affected by adverse weather conditions such as clouds, rainfall or fogs.
    [​IMG]
    3. It has a longer operating distance:
    RADAR technology has a longer operating distance although it takes a longer time to return data regarding the distance of the object.
    4. Cannot detect smaller objects
    It does not allow the detection of smaller objects due to longer wavelength. This means that data regarding very tiny objects on the surface may be distorted or insufficient.
    5. No 3D replica of the object
    It cannot provide an exact 3D image of the object due to the longer wavelength. This means that the image will be a representation of the object but not an exact replica of the object characteristics.
    6. Determines distance from objects and their angular positions
    Apart from the distance from object, RADAR technology can also provide the angular positions of objects from the surface, a characteristic that cannot be measured by LiDAR.
    7. RADAR measures estimated distance measurements:
    RADAR technology does not give the exact accurate measurements of distance and other characteristics of the object because of the distortions.
    8. Radar beam can incorporate many targets:
    A RADAR beam can have several targets at the same time and return data on several objects at the same time. However, this may exclude smaller objects within the target field.
    [​IMG]
    9. Radar may not distinguish multiple targets that are close together
    RADAR technology cannot distinguish multiple targets within a surface that are closely entangled together. The data may therefore not be accurate.
    10. RADAR takes more time to lock on an object:
    RADAR, unlike LiDAR pulses, travels at a lower speed which means more time is needed to lock onto an object and return data regarding the object.
    11. Radar has a wide beam that targets multiple objects:
    RADAR beams are wide and have the capability of targeting multiple objects at the same time. The downside of this is that the data collected may not be as accurate as it should be.
    12. Radar is largely affected by external interference:
    RADAR beams are affected by other external interference such as the forest canopies and dense forest which may limit the quantity and quality of data returned.
    13. Data collection takes a bit more time:
    The collection of data using radar signals take more time than when using LiDAR because radar signals take longer to reach the surface.
    14. Requires an antenna for transmission:
    Radar signals require the radar transmitter to have an antenna for sending and receiving signals from the object.
    15. RADAR is less accurate than LiDAR:
    RADAR data is less accurate than LiDAR data because of the incomplete data returned from radar systems regarding objects. For instance, small objects may not be captured by radar.
    16. RADAR is distorted by noise
    RADAR data may also be distorted based on the noises encountered during the signal transmission. As a result, the data collected may be incomplete or inaccurate.
    [​IMG]
    17. RADAR is used to find range, velocity and position of the object
    The data returned by RADAR signals include the range, of the object, position and even the velocity of the object as opposed to LiDAR which calculates the distance and position of the object.
    18. Cannot penetrate dense forests
    Unlike LiDAR, radar signals cannot collect accurate elevation data from dense forests due to their incapacity to penetrate the dense canopies.
    19. Radar images are of lower resolution than LiDAR images:
    Because of the low speed of transmission and reduced accuracy of the data recorded by radar signals, the resolution of images returned by radar may be of lower quality as compared to that returned by LiDAR.
    20. Applications
    RADAR has a variety of applications including military, security and transport but its main usage is in aviation industry and military weaponry.
  2. DroneTalk
    DroneTalk R/C Expert Staff Member
    470
    42
    11
    Jul 8, 2015
    new jersey
    Posted by DroneTalk, Jan 9, 2018 #2
    Would work great for a current project.
  3. sophia lee
    sophia lee Member
    58
    0
    1
    Nov 22, 2017
    china
    Posted by sophia lee, Jan 16, 2018 #3
    TFmini is a great LiDAR(Top 3 pictures), if you are interested, contact me for more information.
  4. sophia lee
    sophia lee Member
    58
    0
    1
    Nov 22, 2017
    china
    Posted by sophia lee, May 3, 2018 #4
    In order to meet the user's requirement in harsh conditions, we newly added IP65 level waterproof shell to TFmini! In addition, the switching value function is also added. First, let's take a look at the changes in appearance
    [​IMG]
    Left one is the update, pretty cool. Wow!
    If interested, please contact bw@benewake.com
    Those who don't know TFmini before can get familiar with product through the following introduction
    [​IMG]
    TFmini Product Introduction
    TFmini is a milestone for Benewake to promote the process of low cost LiDAR.
    With its unique optical, structural, and electronic designs, the product possesses 3 major advantages: low cost, tiny volume and low power consumption. The built-in algorithm adapted to indoor and outdoor environments can guarantee an excellent ranging performance at a low cost and in a tiny volume, which highly expands the application fields and scenarios of LiDAR and lays a solid foundation for future “eyes” in the smart era.
    [​IMG]
    For more information, please visit our website at http://www.benewake.com/tfmini.html
    The highlights of TFmini updating
    1. Protective shell
    2. Switching value
    1. Protective shell
    In order to meet TFmini's requirement in some harsh environments, we have launched protective accessory that allow the TFmini to meet IP65 protection level, while only increasing a little volume.
    [​IMG]
    2. Switching value
    We update the firmware so that TFmini can output switching value. Current functions are:
    ① The standard UART communication can be switched to the I/O push-pull output via a serial command, and it can also be switched back through the command to achieve one-touch switching.
    ② The distance threshold value of switching can be changed via the serial command to increase the flexibility of uses;
    ③ Default output states: if there are obstacles (range value within the certain distance), TFmini output high level of 3.3V; if no obstacle or out of range (ranging distance outside the certain distance), TFmini output low level of 0V. The the output level can be changed according to requirements.
    Coming soon: Wide power supply voltage of 5-28V; upgrade type TFmini which meets IP65 protection level without customized protective shell; output switching value signal without firmware update requirement and switching value output high level up to 24V. Welcome to contact us!
    Any questions, feel free to contact us via bw@benewake.com
Loading...
Share This Page
Loading...
