From their website:
MaxAmps.com brings you the latest in LiPo battery technology with our LiHV+ Plus FPV Race Edition series. These high voltage batteries will take your high-demand FPV Racer to the next level of power and performance!
High voltage(HV) LiPo batteries can be safely charged to 4.35v per cell resulting in more power and longer flight time compared to standard LiPo batteries that can only be charged to 4.2v per cell. This higher starting voltage yields higher voltage under load, allowing you to fly faster, longer.
Note: 1mm thick battery plates are installed on the top and bottom of the battery pack for added protection from crash damage. Perfect solution for bottom mounted batteries!
https://www.maxamps.com/lihv-1600-4s-fpv-battery
- 1600mah capacity
- 4S 15.2 volts
- True 150C rating
- Lifetime warranty
- 5C fast charge capable
- 100% waterproof
- Built today with factory fresh cells
- Built with genuine 12awg Deans Ultra wire
- We add the connector and JST-XH balancing tap for you
- 1mm thick battery plates installed for added durability
- 64mm x 34mm x 40mm, 175g
