Inspire Radio Connection Issue
Kilby
I'm having an issue with my Inspire and was wondering if anyone else has seen this. The short description is that it loses connection with the radio within seconds of turning it on. For more detail, I power up the radio and app, then turn on the aircraft and it will connect at first. The fan on the aircraft turns on as usual and then after a few seconds the fan and radio connection both stop at the exact same time. Once it does this, it will not connect again if I try to turn it right back on, but will if I let it set for 10 minutes or so. When it turns back on, it's the exact same sequence of events that always end with the fan turning off and the radio dropping connection at the exact same time. I checked the firmware and I'm running the most recent version. This short video shows the problem as it happens on the bench.
