Harvcopter
This is a Harvcopter case for the Immersion 600mw video transmitter. As you can see in the photos this model has a screw down lid so no zip-ties are needed to secure the vTx in place. There are four flat head clearance holes in the base if needed which can be used to secure the case assembly to a frame. The nesting area has the same design as model one and securely holds the SMA in place which reduces or eliminates loads placed on the SMA in the event of a crash. A 90 degree SMA can be used with this case.
