The YEP series ESCs not only offer excellent performance for helicopters, they are also well suited for fixed-wing use with*a whole*host of programmable features.
Hobbyking YEP ESCs are built with the highest quality components to ensure true-to-rating current handling and high efficiency operation.
All Hobbyking YEP ESCs can be programmed via optional programing card or by transmitter stick inputs.
Features:
• Powerful 5.5V/6A Switching BEC
• Optional programming card for convenient setup*
• ESC had separate programming lead built-in so there is no need to unplug from RX
• Super fine throttle resolution provides first-rate and highly accurate linearity*
• Super smooth adjustable start-up mode
• Constant RPM mode (governor mode)
• Adjustable F3A brake.**
• 3 steps adjustable normal EMF brake**
• High anti-interference capability
• Low voltage cut-off protection with automatic adjustment for NiCd/NiMH/Li-Ion/LiPo/LiFePO4**
• Soft cut-off option at low voltage, slows motor RPM gradual rather than hard cutoff (LVC)
• Low voltage cut-off can be disabled**
• Variable cut-off voltage / cell****
• Active free-wheeling circuit allows for unlimited "partial load" capability
• LED status display**
• Adjustable motor timing from 0° to 30°**
• Blocked rotation protection (senses a jammed motor and stops motor rotation)**
• Motor reversing from ESC (no need to change ESC/motor wires)*
• Over-temperature protection and overload alarm**
• Throttle signal lose protection. If the signal is lost for 3 seconds, the power will automatically cut-off.**
• Safe power-on. (Motor will not start until throttle is returned to lowest position)*
***This ESC is compatible with both helicopter and airplane models.***
Specification:
Max Cont Current: 60A
Max Burst Current: 80A for 10 seconds
Input Voltage: 2-6 cells li-XX or 6-16 Ni-MH/Ni-Cd battery
BEC: 5.5V/6A Switching BEC
PWM: 8~16 KHz
Max RPM: 240,000rpm for 2 Poles Brushless Motor
PCB Size: 50x32x12mm
Weight: 63g (including wires)
Features:
Specification:
PWM: 8~16 KHz
