i love nachos
So last week I installed a new gimbal on my hex. 3 minutes into a nice and easy test flight motor 4 shut down. I tested everything and determined a faulty esc. I replaced the esc last night and went out for a test fly today. AL mode was a little wobbly. So I landed and switched to manual. It was insane. Fought it to almost level then flipped AL back on. Once I did that it was violently swinging back and forth. Hit the ground fairly hard but in the landing gear. So I patched up the gear and went to plug it into the setup software to check settings. Now getting a message saying my firmware isn't compatible. I just set the gimbal up last week and I haven't changed a thing. Since HF server is down I can't update. So I decided to go through my radio and see if I noticed any changes. I see I had ALT hold on which I have not figure out yet so I thought maybe that was the issue. So I went back out and not 5 of my motors are shaking like the timing on their escs are off. The props spin as soon as I arm it. So I started to add throttle trim down and they started to spool up and would have taken off but I quickly disarmed it. I am at a loss. I had this thing working great just a short time ago. Anyone have ideas?
