Help there is something wrong with my naza atti mode!?
Hi they are working fine, but now after a flight and some testing I think that my atti mode is actually failsafe and I just got mixed up, could you explain to me the difference between what the two modes do, because I am not 100% sure?
You need to go into assistant and check to make sure your mode switch is making the arrow/highlighted mode light up for each of the 3 positions.
If not, you need to adjust your end points so that the switch lands perfectly on the 3 modes.
Nothing to do with a DJI controller.
You bind your radio with the receiver - and the receiver needs to be connected to the flight controller, just like when you're flying.
Then plug the USB into the computer - open the app and your good to go. Did you not do this before flying???
I didn't set it up my friend did and I bought it off him, but I think it's the sn number that's stopping me using the software, any ideas where I can find it?
I honestly don't know where the serial number would be. But I'm not sure that would prevent you from starting the software.
Have you downloaded the correct software and driver packages for your OS?
