My kit also came without a controller or receiver. I dont have much money so I opted for a cheaper controller, which is programmable. It might be pertinent to get something that you can program, and you will need an app for your computer as well. Many of these apps are free downloads. Your flight controller might have a serial input, be it Sbus or I2c, if you have that it will save you a lot of wiring. The Flysky FS-i6s can be programmed without a computer, it has a touch screen LCD with menu's etc. The receivers come with the controller, but sometimes they market these two things individually. Double diversity receivers are quite cheap (Double diversity means it has two fully functional receivers in one package, the best signal received is used to feed the FC) This also means you will have to download the application for the flight controller, so you can match the channels of the transmitter and the FC. Many of the flight controllers have a mini USB socket, a cable with a standard usb to mini usb is used to couple the FC to the computer. Google the methods used here, there are some good presentations in this regard. The receiver and transmitter have to be "bound" and this being the case you could use the same transmitter with another machine, if you "bind" that receiver to your transmitter. It might sound difficult at first, but do some research on the things you can afford, the firmware and software downloads are not as difficult as it first seems. I use Ubuntu, got a download for that, and a download for Windows is even easier. (One has to add some apps to take care of certain functions). You have chose a hobby that will take you t places you have never been before.....lol
