Welcome To DroneVibes
Help! Motors Won't Spin Now -- S500 Quad with RTFHawk
Discussion in 'Recreational sUAS Flyers Discussions' started by TomCat, Aug 11, 2015.
  1. TomCat
    TomCat Member
    10
    0
    0
    Oct 16, 2014
    Posted by TomCat, Aug 11, 2015 #1
    Built this quad last the winter and have had several successful flights with it.
    Brought it with me on vacation to Colorado. Powered it up to re-calibrate the compass for the new location, and the HK Quanum 2D gimbal did its usual flopping around (camera wasn't installed) and suddenly the gimbal stopped moving.
    Now I am unable to spin up the motors. Everything else seems to work, and I get the armed sound. Have GPS lock. Mission Planner shows it as armed with a correct map location. But, motors will not spin up. Disabled pre-arm check in MP, but that did not help. Loaded it with latest version of firmware and did a re-bind with my Frsky Taranis X9D Plus and X8R receiver. There is power to all 4 of the 30 amp esc's, so the power module and the PCB should be ok. However, when it is armed, I have no power to the motor side of the esc's.
    Not sure how to troubleshoot it from here. Suggestions please???
    Tags:
  2. Motopreserve
    Motopreserve Drone Enthusiast
    4,011
    381
    66
    Nov 23, 2013
    Brooklyn, NY
    Posted by Motopreserve, Aug 11, 2015 #2
    Maybe try plugging the ESC servo wire directly to throttle channel output of the radio (like you do when calibrating ESCs) to see if you're getting anything in that scenario?
  3. Vermiform
    Vermiform Member
    201
    51
    11
    Mar 6, 2015
    North Louisiana
    Posted by Vermiform, Aug 11, 2015 #3
    Unplug the gimbal and verify the problem still exists without it plugged in.
  4. Motopreserve
    4,011
    381
    66
    Nov 23, 2013
    Brooklyn, NY
    Posted by Motopreserve, Aug 11, 2015 #4
    Agreed. I would unplug any extra gear to narrow the focus of your testing.
  5. Vermiform
    Vermiform Member
    201
    51
    11
    Mar 6, 2015
    North Louisiana
    Posted by Vermiform, Aug 11, 2015 #5
    If you fly more than one model with your transmitter, make sure you have it set to your s500 and not something else.
  6. TomCat
    TomCat Member
    10
    0
    0
    Oct 16, 2014
    Posted by TomCat, Aug 11, 2015 #6
    Thanks for the suggestion. I'll give it a try.
    I'm thinking the Taranis X8R receiver may have gone bad. May order a new one to see. Read there have been problems with them due to soldering deficiencies.
  7. TomCat
    TomCat Member
    10
    0
    0
    Oct 16, 2014
    Posted by TomCat, Aug 11, 2015 #7
    Thanks for the reply. The gimbal is disconnected and removed, so that's not the problem. Sorry, forgot to state this in original post.
  8. TomCat
    TomCat Member
    10
    0
    0
    Oct 16, 2014
    Posted by TomCat, Aug 11, 2015 #8
    Thanks for the reply. Nothing extra is plugged in. Sorry, forgot to state this in original post.
  9. TomCat
    TomCat Member
    10
    0
    0
    Oct 16, 2014
    Posted by TomCat, Aug 11, 2015 #9
    Thanks for the reply. The S500 is the only model on the transmitter.
  10. Vermiform
    Vermiform Member
    201
    51
    11
    Mar 6, 2015
    North Louisiana
    Posted by Vermiform, Aug 11, 2015 #10
    Have you removed props and tried motor spin test in mission planner.
    Have you verified in mp that you are in stabilize mode when arming?
    Sent from my XT1080 using Tapatalk
  11. TomCat
    TomCat Member
    10
    0
    0
    Oct 16, 2014
    Posted by TomCat, Aug 11, 2015 #11
    Have not tried motor spin test. Wasn't aware of it but will try to locate it MP and give a try. Thanks for the suggestion.
  12. Vermiform
    Vermiform Member
    201
    51
    11
    Mar 6, 2015
    North Louisiana
    Posted by Vermiform, Aug 12, 2015 #12
  13. TomCat
    TomCat Member
    10
    0
    0
    Oct 16, 2014
    Posted by TomCat, Aug 12, 2015 #13
  14. Vermiform
    Vermiform Member
    201
    51
    11
    Mar 6, 2015
    North Louisiana
    Posted by Vermiform, Aug 12, 2015 #14
    What ESCs are you using?
  15. Vermiform
    Vermiform Member
    201
    51
    11
    Mar 6, 2015
    North Louisiana
    Posted by Vermiform, Aug 12, 2015 #15
    And when you try to arm it while connected to MP, does it say armed on the screen?
  16. TomCat
    TomCat Member
    10
    0
    0
    Oct 16, 2014
    Posted by TomCat, Aug 12, 2015 #16
    Got these from Ready-to Fly Quads: F-30A-HV Fire Red series High voltage (2-6 Cells) OPTO SimonK-(RapidESC)
  17. TomCat
    TomCat Member
    10
    0
    0
    Oct 16, 2014
    Posted by TomCat, Aug 12, 2015 #17
    Yes.
  18. Vermiform
    Vermiform Member
    201
    51
    11
    Mar 6, 2015
    North Louisiana
    Posted by Vermiform, Aug 12, 2015 #18
    Might try re-calibrating your ESCs one at a time and see if the motor will spin up then like Motopreserve mentioned in post 2.
Loading...
Share This Page
Loading...
