Help me with my quadcopter
colliams
I have a problem with my quadcopter and im not sure how to fix it. Here is my problem-when i am flying my quadcopter and the front two props are furthest from me, and i push the stick on my radio left using the yaw or rudder it turns the back of the quad to the left and front to the right. If i push the stick on the radio to the right the back of the quad moves right and the front to the left. I thought that the front of the quad should turn to the left when you push left on the stick and the front should turn right when i push the stick to the right. This may be normal but i just wanted to make sure and see if anyone had any suggestions as to how to fix my problem. I am also using the Hobbyking Multi-rotor control board V2.1. Please post if you have any idea what is wrong and i will try it and get back to you as soon as possible. thanks, colliams
