Welcome To DroneVibes
XAircraft Help determinig cause of crash HELP!!!!!
Discussion in 'General Drone Manufacturer Discussion' started by traxx2003, Jun 12, 2015.
  1. traxx2003
    traxx2003 Member
    111
    6
    1
    Mar 30, 2015
    California
    Posted by traxx2003, Jun 12, 2015 #1
    Tags:
  2. Motopreserve
    Motopreserve Drone Enthusiast
    4,011
    381
    66
    Nov 23, 2013
    Brooklyn, NY
    Posted by Motopreserve, Jun 13, 2015 #2
    One thing that stands out to me is that it shows being in safe mode starting at about 1 minute, 10 seconds or so. Then again at the end. Did you engage that manually? or did it happen due to interference?
    The number look pretty good to me otherwise. Sorry I couldn't be more help.
  3. traxx2003
    traxx2003 Member
    111
    6
    1
    Mar 30, 2015
    California
    Posted by traxx2003, Jun 13, 2015 #3
    That safe mod activation was on purpose, I always like to tested right after takeoff. The last activation was a last effort attempting to save the quad, out of desperation.
  4. Motopreserve
    4,011
    381
    66
    Nov 23, 2013
    Brooklyn, NY
    Posted by Motopreserve, Jun 13, 2015 #4
    Ah. Can you describe the crash, and what happened prior to it?
  5. traxx2003
    traxx2003 Member
    111
    6
    1
    Mar 30, 2015
    California
    Posted by traxx2003, Jun 13, 2015 #5
    I had been flying for about 10-12 minutes doing some mix flying. Then I decided to climb to about 110 meters while on attitude mode. After climbing and holding altitude for a few seconds I noticed that the quad was not responding to any control inputs. Then it decided to fly in one direction while accelerating and loosing altitude at the same time. It was a controlled crash in a sense that the quad was not going crazy in the air. The FC never tried to recover from the dive. The batteries still had 23.9volts each.
  6. Motopreserve
    4,011
    381
    66
    Nov 23, 2013
    Brooklyn, NY
    Posted by Motopreserve, Jun 13, 2015 #6
    And both times the safe mode kicked in was you triggering it - so it wasn't a loss of radio connection.
    Have you powered it up since the crash?
    Have you sent the log to Xaircraft? They may be able to see something that we can't. Hopefully some of the experts here will chime in and notice something.
  7. traxx2003
    traxx2003 Member
    111
    6
    1
    Mar 30, 2015
    California
    Posted by traxx2003, Jun 13, 2015 #7
    Correct, first time I triggered the safe mode as I always do soon after takeoff. The second time was to try t prevent the crash. Yes I sent the log to XAircraft but have not received a reply yet. No I have not powered the quad since the crash because the wiring between motors and ESC's is a mess. I have wires exposed, I'm planing on testing motors separate, the ESC's will be discarded.
  8. Motopreserve
    4,011
    381
    66
    Nov 23, 2013
    Brooklyn, NY
    Posted by Motopreserve, Jun 13, 2015 #8
    Were the wires exposed by the crash? Seems like it would have plummeted down if a motor/esc went out - but exposed wires never sounds good :)
  9. traxx2003
    traxx2003 Member
    111
    6
    1
    Mar 30, 2015
    California
    Posted by traxx2003, Jun 13, 2015 #9
    There is no way for me to know that for certain. It's just so strange that I was able to recover every peace of the wreckage except the GPS pug. But before the accident I can assure you all the wiring was good because I have the habit of inspecting the aircraft before and after each flight and everything was in perfect condition.
  10. Motopreserve
    4,011
    381
    66
    Nov 23, 2013
    Brooklyn, NY
    Posted by Motopreserve, Jun 13, 2015 #10
    That's good practice. The description doesn't sound like a total motor/esc failure anyway.
  11. traxx2003
    traxx2003 Member
    111
    6
    1
    Mar 30, 2015
    California
    Posted by traxx2003, Jun 19, 2015 #11
    Guys today I received and email from Mr. Jingchen at XAircraft support and he said that after reviewing my flight log he discovered that at the moment of the crash the GPS position accuracy was not corrected, indicating to the possibility that the GPS antenna was not positioned/installed accurately. Based on his findings and the fact that I flew fine for the first ten minutes the only conclusion I can draw from all of this is that the FPS antenna came off in flight from its stand. The only thing that confuses me however is that before I loss control I've been flying on attitude mode, and according to someone on this forum when in attitude mode the SuperX does not rely on GPS data but rather on its onboard sensors to maintain controlled flight. If Mr. Jingchen assessment is correct then I guess the GPS had to come off in flight.
    http://log.xaircraft.cn/#2015_06_13_100521.429_76.1.06.07
  12. Motopreserve
    4,011
    381
    66
    Nov 23, 2013
    Brooklyn, NY
    Posted by Motopreserve, Jun 19, 2015 #12
    That blows - especially because it doesn't seem definitive, based on the fact you were in ATTI mode. I had the same impression that ATTI mode would not rely on the GPS for anything - much like what would happen even if selecting GPS, but acquiring no satellites.
    Maybe you could ask him to clarify?
  13. traxx2003
    traxx2003 Member
    111
    6
    1
    Mar 30, 2015
    California
    Posted by traxx2003, Jun 19, 2015 #13
    I did, but they are on a two day holiday in China so I won't hear anything after the 22nd of June. I will update when I get their response.
Loading...
Share This Page
Loading...
