Gimbal control
remyd
Is it possible to manually change the roll through the wookong on a slider switch on your radio. I do it for pitch to make the camera look down but i cannot seem to get roll to move in anyway.
Thanks in advance,
Remy
fritz99
Thanks in advance,
Remy
Hello !
This is one of the big problems of WKM.
It has not enough inputs to control also the roll axis of the gimbal.
I think it is not possible.
Even not with the S-Bus.
I did not find a possibility to do this.
I hope that I am wrong.
Fritz
remyd
Thanks Fritz - i thought as much from what i had read. I guess i will have to plug directly into the receiver, at least i can control the gimbal but i do lose stabilisation but for my photo work i would rather be able to point the camera where i want using a live view from the camera. I will have to look at some of the direct gimbal control boards.
Remy
fritz99
Remy
ok !
But I think this is a major negative point of WKM.
Fritz
remyd
Yes agreed - i am hoping that they upgrade that in firmware or provide a module through canbus but i don't know if they will. I am yet to work out how to use triggering which also seems to come from the same ports. It would be handy to trigger using the waypoints you enter.
