genaceruby
Do you really know what kind of battery is right for your RC cars?The battery you choose is definitely. fit for your vehicles?Now there are some main factors for you to consider when needed. If you have no idea for this field, check your RC cars manual or talk to your technicians for the original equipment manufacturer’s recommendations for:
Technology type:
Different RC cars and driving styles can place varying demands on your battery. It’s important to first determine whether a conventional starting battery will meet your RC car’s needs,Ni-mh battery or Lipo battery.Please keep the same type battery or choose Lipo battery to ensure it runs better.
Battery group size:
This refers to the battery size that will best fit the physical dimensions,terminal locations and type required for your RC cars.Group size is typically based on your RC car’s make,model and engine type. Although some RC cars may accommodate a battery from more than one group size,it is important that you use a battery approved for use in your RC car .Consult a replacement guide to find the?battery group size?that works for your RC cars.Also,make sure your new battery will fit and be held down properly according to the RC cars manufacturer’s specifications.
Check the voltage requirement:
Check the voltage requirement needed to power your RC engine. The label on the engine will provide this information.
Ensure you get a LiPo pack that's the same or similar voltage as the input voltage of the RC engine.See the picture,the original LiPo packs is Gens ace 4s2p,14.8v, 6600mah,then the output voltage from the new LiPo cell is also 14.8v.If you find you can't exactly match the engine's voltage to a LiPo battery pack, then choose one that's the closest.For example, if your RC engine operates on 10 volts, then get a LiPo pack that produces 10.8 volts:but now the lipo 3s voltage is nearly the same when serial connection or parallel connection in Lipo battery.
Check the capacity and C rating requirement:
You’d better keep the capacity and C rating same as the original battery.So from this battery,you need to buy a new 6600mah,35C rating,and the charge&discgarge rating 5C to fit your original one,which can help to keep almost the same battery for using,if you want to change the capacity,please ask the professional supplier in details,then decide the right one.
Check the plug requirement:
The very important thing is that you have to get a same new plug,then you can use this bettery,or it is just a waste when this problem can’t be dealt with.
The environmental temperature:
The higher the CCA rating, the greater the starting power of the battery.
You have also need to be care about the temperature your RC cars work.Maybe your country winter and summer weater is pretty different than many countries,you need to state detaily about this.Cause the original battery of your RC cars you buy from your local place is made exactly fit for the temperature.But when you buy again from online,maybe many overseas supplier,so you need to state the highest and lowest temperature well.Then the supplier can supply the most suitable type and it can work normally.
Warranty:
Look for a hassle-free warranty that includes a free-replacement time frame.
The best way is that you can send your original battery manual to the supplier,if not,please take clear pictures to them.And be sure everything is right and aswer their questions detaily.It is advised that you can buy the original battery again,however,some hobbyists are not very satisfactory about the original one and want to update to better battery,then keep in your mind these main points when purchasing new 5000mah lipo battery.
Technology type:
Battery group size:
Warranty:
