I'm continuing to try to make an XAircraft X650 fly with my OpenPilot CC flight control board. Everything appears to be working now except for my throttle channel. Throuigh the calibration process I'm able to have GCS adjust itself to the throttle movement but when I llok at the values being displayed in the Flight Data page in the lower right corner, throttle starts at -1.0 and then requires almost the entire range of the throttle stick to ever reach a positive number and cause the motors to spool up. I've been able to remedy this by manually adjusting the throttle channel in the Input-Configuration tabs but maybe there's a better way. In the Input-Configuration tabs I was able to increase the minimum value to around 1850 so the range was then 1850 to 2047 and it was flyable but there was a large dead area in the bottom end of the sticks where the motors would go to idle and I came down rather hard at idle as a result.
Would anyone happen to have an idea to fix this problem?
The radio is a Futaba 9CHP with a PCM receiver (72 mHz) if it matters.
Thanks much,
Bart
Thanks much,
Bart
