FPV Regulations 2014 - Update 23 April 2014
mkheng
The latest Order on FPV has today been released. From now you can fly up to 1,000ft FPV proviso:
The person in charge is the person piloting the SUA (The person in charge remains responsible for the safety of the operation and may only fly the SUA if reasonably satisfied that the flight can safely be made.)
The person in charge is accompanied by a competent observer who maintains direct unaided visual contact with the SUA sufficient to monitor its flight path in relation to other aircraft, persons, vehicles, vessels and structures for the purpose of avoiding collisions and advises the person in charge accordingly. (This does not remove the requirement for the competent observer to maintain direct unaided visual contact with the SUA throughout the flight. Therefore, the SUA can only be flown up to 1,000 ft if it can still be seen sufficiently for collision avoidance purposes.)
The maximum take-off mass of the SUA does not exceed 3.5 kg, including any batteries or fuel.
The person in charge must not fly the SUA:
a) in Class A, C, D or E airspace unless permission of the appropriate air traffic control unit has been obtained;
b) within an aerodrome traffic zone during the notified hours of watch of the air traffic control unit (if any) at that aerodrome unless permission of any such air traffic control unit has been obtained;
c) at a height of more than 1,000 feet above the surface (see Note 3);
d) over or within 150 metres of any congested area;
e) over or within 150 metres of an organised open-air assembly of more than 1,000 persons;
f) within 50 metres of any vessel, vehicle or structure which is not under the control of the person in charge of the aircraft;
g) within 50 metres of any other person, apart from the competent observer, except when taking off or landing in accordance with paragraph (h);
h) within 30 metres of any other person, apart from the competent observer, other adjacent model operators, or any model flying club members, during take-off or landing; or
i) for the purposes of aerial work.
The full order is here;
https://www.caa.co.uk/docs/33/ORS4 No. 1011 Small Unmanned Aircraft.pdf
