corygross78
I'm at a loss. Had to rebind my drone now I'm unable to arm the motors
The CC3D is super easy to configure and use! Good choice! The Setup wizard should take you through all the board and transmitter calibration procedures. Try plugging the board in and check the transmitter tab for inputs. Make sure you also tell it what signal you are using becuase flysky Has ibus which your receiver could be outputting without you knowing. Good luck!
Sent from my SM-G570Y using Tapatalk
