farmerfred
Hi,
I'm about to try and fit some sort of siren/alarm to my f550. Ours is a working drone used on a farm to keep pigeons on the move and Im going to add an alarm of sorts to create a large sound to move them on.
I've already thought ahead and installed a deans connector to the main board so i can switch between the zenmuse and siren and any other accessories when I want to.
But what I need help with is the receiver… I would like to make the siren controllable by a switch. I don't use the intelligent orientation control so i thought i'd use this wire from the receiver to control my siren box. But I'm not sure how? What voltage is likely to come from the receiver wire with the 3 wire plug? I'm guessing a low power 3-5v and so ill need a relay switch to then power the siren with 12 from the battery...
something like this:
http://www.maplin.co.uk/p/two-tone-mini-siren-ku65v
or this
http://www.maplin.co.uk/p/mk113-siren-sound-generator-kit-vt28f
and then i would use this small timer to control a 30s pulse of noise for example:
http://www.maplin.co.uk/p/mk111-adjustable-timer-kit-with-relay-output-vt27e
Any help appreciated here folks
or this
