Hello,
I've just built my new ship CineStar 6 with MK electronics. It flies perfectly, I'll post some details on this craft soon. It runs Copter Control for camera stabilization.
Here in Turkey, the weather is getting too hot, it's over 33 celcius right now and under the sun, the motors get hot without starting them. No need to mention, CineStar has no cover for protecting the electronics from direct sun light. The BL Ctrls also get hot because of the direct sun light. (The heatsinks are black and emitting heat). And I have installed heatsinks both sides of BL Ctrl. If it's slightly windy or if I cruise with the copter, heat is no problem. But when hovering under no windy conditions, BL Ctrls have serious heat problems, they easily climb to 100 celcius degrees even heatsinks are installed.
I've put the NaviCtrl and GPS on the arm. And trying to place a fan to CineStar battery tray.
I know that brushless fans generate magnetic field which disturbs the compass functions. But does it generate more magnetic field than a brushless motor that we use? In this setup, I'm using Tiger MT2820 KV830 motors.
Does anyone had a experience with a fan installation? I made sure the fan is far enough from the NaviCtrl and GPS.
