F550: Slow engine spool up on M1
chipwich
Greetings. Yesterday, while flying at a local park, I almost aborted the F550 for the day. M1 did not start after arming. That was strange, because I had tested it before leaving home. I reconnected the motor/esc, but no change. Then I noticed that if I gave 3/4 power, or just enough to begin lifting, that it would begin to turn normally. I decided to put it in the grass, do a short take off and hover, but it flew normally. In fact, I put two more packs through it without any issues. Later that day, it exhibited the same behavior. The only difference was the ambient temperature. My house is around 70 F, and we were ~ 40 F and lower at the park yesterday, so at least 30 degrees colder. I'm thinking that I might have an engine about to go tango uniform. What do you guys think? Thanks.
