F550 build and question(s)... Can anyone help?
Flymagic
Hi there,
Building a F550 with Orange 910 DSM2 RX, Naza M Lite w/GPS, and DX8 TX.
Tested it with an Spektrum 6 channel receiver, but realized I needed more working channels.
Original test flight was right front heavy, and was taking off and leaning on right front leg.
How an I adjust the hex to normal that out.
Now that I've put in the orange rx, motors 5 and 6 are not spinning up. Checked the ESC connections
to the NAZA and they look good, still no action. Pulled out the #6 connector and Naza started beeping.
Does this mean NAZA sees it, but is not powering it?
Is there an ESC calibration I should be going through?
I would really appreciate any guidance, as this is my first build.
Thanks.
Flymagic
Gambrinus
Im too much of a newb to confidently answer your questions but if I were you I would try to isolate the problem. Switch out a motor with one known to work, then switch out an esc to another position. make sure all your connections are correct and secure.
Good luck, its a real pita when you get a problem like this.
JoeBob
Elevation via Flatulation
Silly question: Do you have a Hex selected in the NAZA Assistant, and not a Quad. I only asked because motors 5 and 6 would be the 2 motors that a Quad setup would not be looking for in the NAZA.
