Jimbodiddly
Hi All,
I"ve just finished the build on my f450 & configured it in the assistant ' no errors showing now' it has been setup with a Futaba t8j & the tx has been set accordingly. voltage motoring is on, however I have not changed anything apart from the cell type.
It has been upgraded to the latest firmware and from the assistant side of things it appears to be fine.
However when powered on it will not arm, I just get the following led sequence in gps mode, single green flashing led when sticks are centred an no throttle when in using the sticks to arm it blinks faster but only 2 blinks in a short burst. and in attitude & failsafe I get yellow/ red leds blinks in the same patterns as above.
Have i missed anything obvious ?
Thanks in advance
Jim
Thanks in advance
Jim
